Mike Matthews
- Aug 1, 2003
Mains:
JBL Northridge Series Floor Speaker with Dual 10" Woofers ($284)
Product Features
Maximum power-handling capacity: 250 watts
Sensitivity: 91dB
Dual 10" PolyPlas woofers
4" PolyPlas midrange driver
3/4" titanium-laminate dome tweeter with EOS waveguide for even dispersion
Magnetically shielded for use near video monitors
Kapton voice coil and HeatScape motor structure for rapid heat dissipation and high power-handling capacity
Low-diffraction IsoPower baffle directs the sound power into the room, reducing distortion caused by cabinet vibration
FreeFlow flared port increases bass response without adding unwanted port noise
Straight-Line Signal Path (SSP) crossover networks minimize signal degradation
Frequency response: 37Hz - 20kHz
Center/Surrounds/Sub:
JBL 5-Piece Home Theater System ($330)
Product Features
High-impact molded enclosure
PolyPlas cone woofer
High-frequency driver: 3/4" titanium-laminate dome
Frequency response: 75Hz - 20kHz
Impedance: 8 ohms
Power rating: 100W bookshelves, 150W center
Sensitivity: 86dB bookshelves, 90dB center
Bass driver: 4" PolyPlas bookshelves, 5" PolyPlas center
OR
how does this system stand up?
Infinity Entra home theater system
Key Features:
Entra Two:
3/4" C.M.M.D. tweeter
6-1/2" C.M.M.D. woofer
frequency response 50-20,000 Hz (±3dB)
sensitivity 90 dB
31-3/4"H x 8-1/2"W x 9-3/4"D
Entra One:
frequency response 60-20,000 Hz (±3dB)
sensitivity 89 dB
15"H x 8-1/2"W x 9-3/4"D
Entra Center:
dual 4" C.M.M.D. woofers
frequency response 95-20,000 Hz (±3dB)
sensitivity 89 dB
17"W x 6-1/2"W x 5-1/4"D
Entra Sub:
150-watt (RMS) amp
10" front-firing C.M.M.D. driver
frequency response 34-150 Hz (±3dB)
continuously variable 50-150Hz crossover
speaker-level and preamp-level inputs
15"H x 14-1/2"W x 17"D
System specs:
video-shielded (except Entra Sub)
frequency response: 34-20,000 Hz (±3dB)
handles up to 125 watts
8-ohm impedance
5-way binding posts (except Entra Sub)
black ash vinyl finish
warranty: 5 years
Product Features
Sensitivity: 91dB
Product Features
Impedance: 8 ohms
OR
Key Features:
Entra Two:
sensitivity 90 dB
Entra One:
sensitivity 89 dB
Entra Center:
sensitivity 89 dB
Entra Sub:
150-watt (RMS) amp
System specs:
8-ohm impedance
warranty: 5 years
