Would this be a worth while move?
Discussion in 'Archived Threads 2001-2004' started by Kevin. W, Nov 11, 2001.
  1. Kevin. W
    Kevin. W Screenwriter
    Oct 27, 1999
    1,534
    Currently my setup consists of:
    Denon 1801
    Rotel RMB-1066(3x150 powering fronts/centre)
    Paradigm Mini Monitors/CC350/PS1000
    My dillema is wether or not too purchase a Marantz AV560 Pre/Pro(DD/DTS)($450US/$700CDN) to replace my Denon which would complete my move to seperates. Currently my HT is used 100% movies. If I can sell my Denon the move would only cost $100-$150CDN. What do you guys think? One other question: Would it make much difference that the crossover of the Marantz is 100Hz compared to the Denon's 80Hz. My speakers are all set to small.
    Kevin
  2. brentl
    brentl Cinematographer
    May 7, 1999
    2,921
    110
    I honestly don't think you'd be gaining much since you are using both as preamps.
    Brent L
    OK guys ..... The tour of the Paradigm
    plant is now being planned. GO TO THE HOME THEaTER
    MEETS PAGE and register.
  3. Kevin. W
    Oct 27, 1999
    1,534
    Thanks BrentL for you input. I kinda figured that I wouldn't be gaining much from going from the Denon to the Marantz. Both do DD/DTS. What I looking at is the fact that I don't need the Denon except for doing the processing. My AMP can be configured to 5x70 leaving the Marantz to do what it does best.
    Kevin
