Would this amp work to power an SVS 20-39 CS?
Discussion in 'Archived Threads 2001-2004' started by Troy LaMont, Feb 13, 2002.
  1. Troy LaMont
    Troy LaMont Supporting Actor
    Mar 11, 1999
    849
    I've decided for now to use an old two channel (150 watt per channel) amp that I had to power a 20-39 once I made my purchase.
    In looking at the specs the other day for the amp, I noticed that it's frequency response was only 40Hz-20KHz!
    Will this not give me what I need in the lower frequency range (below 40Hz)?
    Thanks.
    Troy
  2. Steve Stogel
    Steve Stogel Supporting Actor
    Jul 19, 2000
    600
    Well, one way to find out is to get a CD with a frequency sweep starting at or below 20Hz. I've got VE (which doesn't [​IMG]), but doesn't Avia have a sweep? I did just buy a test CD from Stryke Audio that has 30-second intervals from 10Hz up to 20KHz. That way you'll know if your amp is passing the signal. Hope it is [​IMG].
    Steve
    P.S. FWIW, I had to buy a small amp from RatShack (using it, basically, as a line level to speaker level converter for my sub amp, which only has speaker level inputs) that is rated 20-20K, and with the Stryke test CD, my sub is getting the signals below 20Hz. I can feel 10, 12.5, et cetera. The 15Hz signal shakes the crap out of my walls [​IMG].
  3. Troy LaMont
    Mar 11, 1999
    849
    Steve,
    Thanks for the response.
    Tom/Ron,
    Any input?
    Thanks.
    Troy
  4. Troy_K
    Troy_K Stunt Coordinator
    Jan 20, 2002
    87
    Troy,
    It's likely that your amp is only "rated" at 40-20K. That doesn't mean it can't do it. You can always try. Testing it with a bass CD as suggested above is a good idea.
    Troy (what's in a name, anyway..)
  5. Troy LaMont
    Mar 11, 1999
    849
    Ron/Tom?
    Troy
  6. SVS-Ron
    SVS-Ron Screenwriter
    Jun 2, 2001
    1,074
    Troy,
    Sorry for the late feedback. E-mail is best when you really need a response.
    I'd guess that amp is actually capable of producing power well below 40Hz but it's hard to say for sure. I can't imagine one that has a subsonic filter set so high.
    As with many things there is one certain way to find out.
    Ron
