Would PAL work on NTSC receivers?
Discussion in 'AV Receivers' started by BarOr, Apr 22, 2004.
  1. BarOr
    BarOr Stunt Coordinator
    Apr 18, 2004
    74
    I was wondering, on some receivers it says at the video Specification part:
    "Video
    Television Format: NTSC" (for example marantz, hk)
    What that means? Can't I use the video entrances and exits runing PAL movies and tv? Let say I watch a movie on DVD (on pal format) the DVD is connected to TV by the receiver would it work?
    Would the on screen menu will work?
  2. Scott Barnhart
    Scott Barnhart Stunt Coordinator
    Jan 3, 2001
    202
    It works for me. I switch a PAL VCR and a PAL DVD player through the video section of my receiver (Denon AVR-3600), and it works perfectly - never had any trouble.
    As far as the "Television Format: NTSC" thing, that probably just means that the receiver's own onscreen menu is output as NTSC, which would be normal in an NTSC country.
