Would calibrating with a Sound level meter
Discussion in 'Archived Threads 2001-2004' started by Rod Melotte, Feb 26, 2002.
  1. Rod Melotte
    Rod Melotte Stunt Coordinator
    Jan 7, 2002
    237
    Would calibrating with ONLY a Sound level meter be worth while. Taking each speaker and having the same amount of white noise hitting my ear?
  2. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    I don't understand the question. Using only a SPL meter, you would have nothing to measure. You need some sort of tone or signal to measure with the meter- although your receiver should have some tones that will get you in the ballpark- Avia or VE will get you right on, and both are very affordable.
    You probably can't do it "by ear" (which the second sentence in your post alludes to)-- you will need a meter and some form of calibrated tones.
    -Vince
  3. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    yes, it would still be a worthwhile exercise. that way, you can use the test-tones from the receiver and still ensure that all the speakers are volume-matched.
    the benefit of utilizing a calibration dvd is that you'll hear the tones all the way through the signal path: from dvd to receiver to speaker. calibrating with only the spl means you'll leave the dvd out of the "final" equation.
    but it's still a good move to use the spl. with the spl, i was able to fine-tune my speakers by a db here and there.
  4. MikeyWeitz
    MikeyWeitz Supporting Actor
    Feb 10, 2002
    939
    Boy, this must be the same Rod Melotte from the VDOT boards :)
  5. Vince Maskeeper
    Jan 18, 1999
    6,499
    Mikey,
    What's a VDOT board?
    -Vince
  6. MikeyWeitz
    Feb 10, 2002
    939
    Vdot is a stock. If this is the same Rod Melotte I am thinking of, he is a friend who has a personal VDot chat board on Raging Bull.
  7. Rod Melotte
    Jan 7, 2002
    237
    LOL - it's me, but I'm surprised anybody is calling me a friend after THAT nosedive.
    I have
    MVL
    FRED
    PETM
    MET
    VDOT
    Staying away from tech for a while.
    SORRY - OFF TOPIC
