Woofer Placement (1 Viewer)
Reid K
Okay my area which I will be setting my stuff up is fairly small and was wondering were the ideal place for me to put my woofer would be. BTW it is floor firing if that matters.
Neil Joseph
Neil Joseph
Simple answer - Try up front with your main speakers, corner placement.
longer answer - Place the sub in the listening position then play a constant tone only in the sub. Walk around the room to find the spot where the sub is at its loudest. Place the sub in that spot. Only problem is the sub may be in the middle of a walkway.
AlohaTiger
