Bob Sorel
- Dec 30, 1999
Hi guys,
Since it looks like I will be building speaker cabinets and subwoofers for some time to come, I figure that I should invest in some decent power tools. The Craftsman, Skil, Black and Decker tools that I already own are dying one by one, and I would like to replace them with better quality tools, hopefully at good prices.
For example, about 6 months ago I bought a Grizzly table saw, and this is an absolutely wonderful tool at a very reasonable price. It has a very powerful motor, a smooth, accurate "Shop Fox" fence, and cast iron wings, and I bought it brand new for about $525, if memory serves. Comparable products from Delta, DeWalt, or Jet cost $900 to $1000, and in some cases were not as good.
One of my mistakes was to buy a Craftsman router. The plastic housing actually broke on the inside, allowing the armature wobble badly. Luckily I had bought the replacement guarantee for an extra $6, so Sears replaced it free of charge. I have no confidence in this product, and the extended warrantee will be over soon, so when (not if) it breaks again, I would like to replace it with a better unit.
My Craftsman sander and Skil corded drill both bit the dust recently, and my Ryobi cordless drill won't be far behind.
So my questions are these:
What power tool company builds rugged, reliable good performing tools for the lowest cost?
Are Grizzly's other power tools as good as their table saws?
Do you recommend buying any particular company's "set" of power tools, or should all tools be bought individually?
Where's the best place to buy power tools?
Please make recommendations on the following:
Router (plunge not necessary, but useful)
Sander (preferably small and lightweight)
Corded drill
Cordless drill (18 volts?)
Non pneumatic stapler, brad, and/or nail gun
Jigsaw
I am not doing woodworking for a living....just a hobby, but I want to use quality tools that will not need replacing a year from now. I will appreciate any and all recommendations.
Bob
[Edited last by Bob Sorel on November 16, 2001 at 05:58 PM]
Corded drill
Jigsaw
Bob
