Woodworking classes
Discussion in 'Archived Threads 2001-2004' started by Andres Munoz, Mar 13, 2001.
  1. Andres Munoz
    Andres Munoz Cinematographer
    Dec 21, 1999
    2,489
    Seeing such wonderful DIY projects have made me want to learn how to work with wood.
    Any idea if classes are available in the NYC area?
    Andres
    http://home.earthlink.net/~coolvirus/
  2. Carl K
    Carl K Auditioning
    Jun 22, 2000
    2
    Andres, I can't speak to woodworking classes in NYC (although I'm sure they have them - try the technical colleges and high schools for low cost courses) BUT...I speak from experience that if you get hooked on woodworking, you will definitely have a lot less time to spend on HT [​IMG] Enter cautiously, it is another slippery slope.
    To the good, the upgrade bug is a lot less fierce in woodworking. [​IMG]
  3. MarkDesMarais
    MarkDesMarais Stunt Coordinator
    Aug 24, 1999
    71
    What do you mean the upgrade bug is less? Clearly, you must not have seen the 14" 3-phase table saws, or the 24" thickness planers. And how about that whole dedicated BUILDING that you need to REALLY do it right!! ;-)
    Markd
  4. Andres Munoz
    Dec 21, 1999
    2,489
  5. James Mudler
    James Mudler Stunt Coordinator
    Feb 1, 2001
    207
    Many specialty suppliers (for example woodcraft stores)have traning in their stores. I learned pen making at my local Woodcraft store. Hope it helps
    James
    Luke, I'm your father
  6. Andres Munoz
    Dec 21, 1999
    2,489
