Witch Hunter Robin Box Set
Discussion in 'DVD' started by Adrian P, Jun 24, 2004.
  1. Adrian P
    Adrian P Stunt Coordinator
    Sep 16, 2003
    65
    I have been interested in getting a box set of this series and found this link:
    www.discountanimedvd.com/dvd_detail.asp?dvdno=5475
    This set is really cheap compared to buying the volumes...
    Anyone know any websites with a review of this box set?
  2. Adrian P
    Sep 16, 2003
    65
  3. svenge
    svenge Stunt Coordinator
    Apr 2, 2003
    153
    It's a bootleg.
  4. svenge
    Apr 2, 2003
    153
    It's a bootleg.
  5. jason:g
    jason:g Stunt Coordinator
    Apr 16, 2004
    242
    It's a China edition/release, and the discs are packaged in digipack. According to that page, some people have written that there are slight grammatical errors.
    China and Hong Kong releases are usually very cheap (especially if you buy them directly from Hong Kong). That price is even lower than what I can get it for here. [​IMG]
  6. Adrian P
    Sep 16, 2003
    65
    So should I buy it? If I were to buy the volumes separately, it would cost 4 times the amount of this set...
  7. jason:g
    Apr 16, 2004
    242
    Well, I don't know if you should buy it. The quality isn't so good.
    I'll be waiting for the live action movie [​IMG]
  8. Adrian P
    Sep 16, 2003
    65
    I guess I will by the volumes instead (for better quality).
    Thanks.
