Ted Lee
- May 8, 2001
hi all -
i recently setup a wireless network using a HP wireless router. (hn200?). i combined it with a linksys usb adaptor and it works perfectly. setup took like 10 minutes.
but when i tried to enable WEP (which i'm thinking is a good idea) i ran into some problems.
i enabled the WEP radio button on the hp software, but the whole thing just shut down. after about 20 minutes i was able to restore the whole setup.
so, did i do something wrong? i noticed on the WEP configuration a field that had like 16 digits in it. i wasn't sure what that part was about. was i supposed to modify it or something?
also, i assume i need to do some additional configuration on the linksys adaptor?
finally, have any of you guys done the MAC filtering thing? or changed your SSID?
i want to enable some level of security, but i hope to not take too much of a performance hit.
thx,
ted
thx,
ted
