Chad Seymour
- Feb 28, 2000
I'm not actually sure where this topic should go, so you might see it in another forum also.
I'm trying to figure out how I'm going to set up my wireless network before Xbox Live comes out. I have already purchased the Linksys BEFW11S4 Wireless AP/Router/Switch. I'll probably just go direct wire to the Xbox for a time, but eventually, I'd like to tidy this up. The wired route will be a major pain in the rear since I live on a slab foundation and do not have access to the overhead area to drop a line near my entertainment center. So for the time being, I will have to deal with a CAT5 cable running from the computer room to the living room and unhook it when I'm done.
I got to thinking about other possibilities last night and basically what I was wondering was this. If I connected my Xbox to a 2nd BEFW11S4, would it talk to the primary? For some reason, all of the Linksys components tend to run right about at the $100 range. So instead of plunking down $100 for the WET11 wireless bridge, could I just plunk down the $100 for another BEFW11S4 and have additional ports available? This could work out really well for me because I have a TIVO with a burned out modem which I could add into my broadband wirelss net. If I added the capability to the Tivo (Turbonet), then I could plug both the Xbox and the Tivo into the 2nd wireless switch and they should both talk, right? This makes sense to me, but I haven't tried it out yet. Any network gurus out there with Linksys product familiarity?
And why do all the wireless products cost about the same, regardless of what there function is?
Chad
Chad
