Hi,
I've just bought a new TV (LG 42LE5300) and I want to connect it to my computer via HDMI. The trick is that I want to do it remotely by using my wireless N network.
I don't want to use a streamer, I just want to convert wired HDMI cable into a wireless one.
The closest tool I found was this:
http://www.edimax.com/en/produce_detail.php?pd_id=284&pl1_id=16&pl2_id=77
But it's too expensive for my simple task.
What method or tool would you suggest me to use?
Thanks ahead for you help.
