Colin Davidson
- Jan 6, 1999
Greetings,
Need some advice from the "crew" on which wireless desktop card to get.
Here is my story thus far:
Due to my wife's quarterly "lets move the furniture around" drill my desktop PC which was located in the dining area next to the cable modem has now been moved to an empty bedroom and I now need to connect wirelessly. I currently have a LinkSys WRT54G connected to my cable modem which works great for my work laptop and daughters laptop connection needs.
I purchased a LinkSys WMP54G (PCI card) and spent about 12 hours trying to get it to work. It would connect to the WRT54G but I would never get an IP address. I tried everything I know of to get it going with no success. LinkSys' web site has plenty of complaints from people who have had the same problem with this card. The only set of drivers was in November 05 and they are not WHQL. I also tried installing the card only and using WinXP for the wireless configuration but I was getting an error that said that some other software was controlling the wireless configuration - and this was even after I uninstalled the LinkSys software and rebooted.
I will be returning it as defective and getting something else that will hopefully work. I would appreciate any recommendations on what to go with that you have had success with getting it installed and working.
Colin Davidson
Colin Davidson
