JamesED
- May 23, 2004
I occasionally lose my connection, as described in this linksys and windows knowledge base links.
I either have to restart my computer or unplug and replug my adapter. I am using the Linksys WUSB54G G USB adapter. I can't use a card, because my apartment complex insists I use this adapter to connect.
The Linksys page says I need to go to the properties of the adapter, and to the authentication tab and turn off the IEEE 802.1x authetication. The problem is I don't have this tab, and it links to the windows base that acknowledges the problem. The windows page doesn't seem to offer a solution, only suggesting to pay for their support phoneline.
Anyone know what I can do? I can only turn off the authetication for each wireless router I want to connect to. I only connect to one and it's off, but if I uncheck authetication for the other routers, windows reenables it after I close the window. I only have the router I want to connect to on my preferred list, and I have checked the box to only connect to routers on the preferred list. I assume authentication is still my problem. I went for 4 days without a problems, but in the last 18 hrs I've lost connection 5 times.
Linksys solution page
Windows Article
Windows Article
