wireless A/V sender question
Discussion in 'Home Theater Projects' started by DavidF., May 26, 2004.
  1. DavidF.
    DavidF. Auditioning
    May 25, 2004
    Hello all,
    I would like to connect my Media Center PC to my TV and NAD amp, which are one floor below and on the other side of the house. I found this product, the RCA WVS150 2.4Ghz A/V sender, which is supposed to perform this function quite nicely. My questions:
    1) Has anyone used one of these? If so, what is the signal quality if traveling ~100 feet and through a couple walls?
    2) It advertises that it also relays remote IR signal, but it's not clear whether this is just for RCA remotes or for any remote.
    3) Will the 2.4GHz interfere with my WiFi router?
    Thanks!
  2. Eric Samonte
    Eric Samonte Screenwriter
    Mar 31, 1999
    1,318
    My suggestion is get a set and try it out where u can return it. Mine is from X10 with no remote relay. It worked fine for me across one floor and 3 walls in less than 100 feet. Audio was fine and video quality was acceptable on a 27" set. Now I have not tried it on anything bigger than that so YMMV.
