Wire under carpet
Discussion in 'Archived Threads 2001-2004' started by Ken Leggatt, Dec 5, 2001.
  1. Ken Leggatt
    Ken Leggatt Stunt Coordinator
    Jan 31, 2001
    94
    Hi,
    I just moved into a new rental place and do not want to put holes in the walls big enough to mount my Klipsch RS-3's properly. So to get around this problem I ran my 12 gauge Home Depot wire under the carpet. The previous tenants cat clawed a small hole by one of the doors and I pulled up one corner and ran the wire under between the opening of the door in the room. The question is this, will this be dangerous? Can a fire be caused or the amplifier be damaged? Please let me know if it will!
    Ken [​IMG]
  2. PatrickM
    PatrickM Screenwriter
    Aug 10, 2000
    1,138
    If your not exposing any bare wire it shouldn't be an issue.
    Patrick
  3. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    If enough wear & tear caused (by walking over the cord) removed all of the insulation, you'd have a problem, but I'd be more worried about people tripping over the 'bump' in it first. Just route it under furniture and tell your friends where the bump is.
    Glenn
  4. PeteD
    PeteD Stunt Coordinator
    Mar 13, 2000
    110
    Can an exposed speaker wire cause a fire?!?! I guess it makes sense, I just never thought of it! Can you get electrocuted by exposed speaker wire? Does the volume need to be turned up?
    As I said, I never really considered it!
    P.
  5. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    As far as I know, speaker wires run under carpet do not pose a fire or electrocution hazard but...
    The speaker wires could fray as people walk on the carpet, causing a short circuit that could fry the amp.
    The louder the sound, the more current is going throught he speaker wire.
    Video hints:
  6. Wayne A. Pflughaupt
    Aug 5, 1999
    6,098
    33
    Katy, TX
    Wayne
    Ken,
    I did the very same thing in my HT. My left main speaker was on the other side of a doorway, and I pulled a hunkin’ 12ga. wire under the carpet. It is barely noticeable (we have a thick pile rug). The only way you can feel it underfoot is if you aren’t wearing shoes. It's been in place 13 years, no problems.
    Happy Holidays,
    Wayne A. Pflughaupt
  7. Francois Caron
    Francois Caron Cinematographer
    Jul 31, 1997
    2,143
    Francois Caron
    My rear left speaker wire is under wall-to-wall industrial carpeting with underpadding. You can see and feel the bump, but even when stepping on it, it doesn't go anywhere and doesn't appear to be wearing down.
    Whatever you do, DON'T EVER RUN ELECTRICAL WIRE UNDER A CARPET! At 120 volts, a short can start a pretty bad fire.
  8. Ken Leggatt
    Jan 31, 2001
    94
    Thanks for all you input. I think that I will leave the wire where it is!
