David K.
- May 14, 2004
http://www.partsexpress.com/pe/showd...number=080-526
i just purchased this wire loom to help dress my speaker cables, i held it over an open flame to see how flamable the material was, and after a bit it would catch fire and stay on fire. Im concerned about the safety of the wire loom, I would think that since it is used to hold electrical wiring, then fire hazard would not be a big problem. But because it caught flame has me concerned.
if my speaker cables were to have a short, or if over time the cable cracks and the wire look is exposed to bare copper running electricity, what is the likelyhood of it catching fire? Should i look elsewhere for cable management material? i am right now using it to dress my cables under 1" heat shrink. and im concerned about fire issues, should i be concerned?
should i be using more expensive flame retardent looming for my speaker cables?
