WinXp on old computer?
Discussion in 'Computers' started by Geoff::L, Nov 23, 2004.
  1. Geoff::L
    Geoff::L Agent
    Dec 11, 2003
    29
    Is it better to install WinXP Pro or Win2k on a 533MHz computer? I think MS website says 233MHz min. for XP but I am still unsure.
  2. Scott Shanks
    Scott Shanks Second Unit
    Mar 10, 2001
    380
    Louisville, Ky
    Scott Shanks
    Geoff,
    I am running XP Home on a PIII 550 with 256Mb RAM and it runs fine. Not lightening fast, but no speed problems related to the OS.
  3. Geoff::L
    Geoff::L Agent
    Dec 11, 2003
    29
    Thanks Scott! WinXP it is then.
  4. Carlo Medina
    Carlo Medina Executive Producer
    Oct 31, 1997
    10,451
    651
    I've successfully put it on several old PIII 450s with 256MB RAM (though they were happier when I was able to bump one up to 384 and the others to 512 RAM). One word of caution, you may want to disable the new UI and make it look like Win2K in appearance, as that helps performance a bit.
    but otherwise you should be fine.
  5. Mike Fassler
    Mike Fassler Supporting Actor
    Jan 17, 2004
    523
    ive had xp running on a 266 pentium II system before, it worked fine, just needed a grip of ram.
