winme user names/login
Discussion in 'Computers' started by Rob Rodier, Aug 19, 2003.
  1. Rob Rodier
    Rob Rodier Supporting Actor
    Jul 11, 2002
    538
    I recently inherited a pIII pc running windows me.
    My problem is that I need to sign in as a guest and consequently am not allowed to make any signifiacant changes to the system, or even uninstall older programs.
    Is there any universal sign-in that will allow me access to uninstall etc?
    -rob
  2. nolesrule
    nolesrule Producer
    Aug 6, 2001
    3,084
    Clearwater, FL
    Joe Kauffman
    Why do you need to sign in as a guest? I would assume it's because you don't have the password for a user with admin rights?
    If that's the case, then I recommend backing up important data and just do a wipe and install (it's the most reliable uninstall of all. I'd also recommend using a version of Windows other than WinMe.
  3. SteveA
    SteveA Supporting Actor
    May 25, 2000
    700
    I always thought that ME (like Windows 98 and 95 before it) did not have real user security. I thought the user login was simply to allow different preferences for different users (desktop layout, screen savers, etc.).
  4. Rob Rodier
    Jul 11, 2002
    538
    Thanks for the responses.
    I do need to sign in as a guest, due to the fact that the password and sign-in for the original master user-name was lost.
    Can you please tell me more about the wipe & install. I am not familiar. Your help is greatly appreciated.
    I agree that ME stinks, but it is going to have to do for a few months...
    Thanks again.
    -rob
  5. Matt DeVillier
    Matt DeVillier Supporting Actor
    Sep 3, 1999
    773
    Rob,
    hit ESC when presented with a login prompt and go about your business as normal - you will have full "admin" rights as this point. search for all files ending in .PWL (password lists) and delete them. reboot, and when you start up you will be presented with a dialog asking you to set a user name and password. leave the password blank if you don't want it to bother you again
    -Matt
  6. nolesrule
    nolesrule Producer
    Aug 6, 2001
    3,084
    Clearwater, FL
    Joe Kauffman
    Matt, I completely forgot about that little security hole. [​IMG]
  7. Rob Rodier
    Jul 11, 2002
    538
    Sorry for the dealy. I have been out of town.
    Thanks for the reply Matt. That is exactly what I was looking for.
    -rob
  8. Lee L
    Lee L Supporting Actor
    Oct 26, 2000
    868
    I'm pretty sure you can even click the X close window box on the password dialog. That way you won't even have to reach down to the keyboard. [​IMG]
