Windows XP Pro: 32-bit or 64-bit?
Discussion in 'Computers' started by Ronald Epstein, Aug 8, 2003.
  1. Ronald Epstein
    Ronald Epstein Founder
    47,670
    5,060
    Had to download a security patch.
    The choices under Windows XP was 32-bit or 64-bit.
    Wow! Didn't know.
    I selected 32 bit.
    Now my computer is starting to dump memory
    and freeze.
    Did I pick the wrong door?
  2. Gabriel_Lam
    Gabriel_Lam Screenwriter
    Mar 7, 2002
    1,402
    There are 5 versions, 4 are 32bit:
    XP Pro: 32bit
    XP Home: 32bit
    XP Media Center: 32bit
    XP Tablet PC: 32bit
    XP 64-Bit: Take a guess. [​IMG]
    You probably downloaded the correct one.
    You can double check by going into system properties. It should say right there what OS you have.
