Windows XP Issues (need Help)
Discussion in 'Archived Threads 2001-2004' started by Brett DiMichele, Feb 16, 2002.
  1. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    Hey fellas,
    My new PC came from Micron and I am very pleased. Every
    component in the system is name brand and even the fans
    are top quality (4 fans total)
    I went out and bought a USB cable for my printer and it
    works great, Bought a MS Intellimouse USB Explorer Optical
    and it works great too!
    XP is alot better than I expected! But I can not get my
    Parallel Scanner or my Parallel Zip100 drive to work..
    My problem is that I have this great IBM 32 Bit Legal Size
    Flatbed but it was meant for 3.1 and 95.. I went to IBM's
    web site and I see absolutely no drivers for anything newer
    than 98.... And I doubt they are going to make any because
    they don't make scanners now.. So I guess I am going to
    end up selling this mint, boxed scanner cheap so I can buy
    a USB Scanner that will work (frown....)
    As for the Zip, I beleive I need to change my Parallel Port
    settings in the Bios.. It's currently on SPP and Iomega told
    me to set it to ECP so that it transfers faster.. It's so
    slow now that it hangs...
    Any ideas?
  2. Brian Bowles
    Brian Bowles Second Unit
    Dec 3, 2001
    256
    Try the compatability wizard and install it like it is windows 98.
  3. Brett DiMichele
    Sep 30, 2001
    3,181
    Thanks fellas..
    I went into the Bios and set the parallel to ECP and still
    no luck with the scanner or zip drive.
    I bet that 2000 drivers and running in 2000 compatibility
    mode would work but I have decided I am just going to sell
    my Zip Drive, Printer, Scanner and buy a LeXmark all in one
    Scanner,Printer,Copier and forget the zip drive.
    Zip Drives don't make any sense, media is nearly $100.00
    for 1 GB worth of media (10 disks) you can buy CD-RW's for
    $2.00 each, CD-R's for $30.00 per 100 disks and you can
    flat out buy hard disk drives cheap.. So I can not see the
    point in even owning the Zip drive anymore.
    I guess I will place all this stuff (Mint Boxed) in the
    Hardware for Sale section and on Ebay...
