Windows Media Encoder problems
Discussion in 'Computers' started by Jeff Jacobson, Mar 13, 2004.
  1. Jeff Jacobson
    Jeff Jacobson Cinematographer
    Dec 24, 2001
    2,116
    I am trying to create a Windows Media file (WMV), but every time I try to create such a file, the program crashes. I've tried using Windows Movie Maker and Windows Media Encoder. Both programs stop responding as soon as I try to save a file as WMV.
    I used to be able to use Windows Movie Maker to create WMV files, but I recently installed Windows Media Encoder, and now I can't use either program to create the WMV files.
    I started another thread about MPEG-2 playback problems in Windows Media Player which also started after I installed Windows Media Encoder. (Since I think the problems may be related, I posted the link.)
    Can anyone help me fix this problem?
  2. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    What are your source files? WME is picky about which files you try to convert.
  3. Jeff Jacobson
    Dec 24, 2001
    2,116
    I was trying to convert an AVI file. The video (720 x 480) was compressed with HuffYUV, and the Audio was uncompressed.
    Prior to installing Windows Media Encoder, I was able to use this kind of file as a source in Windows Movie Maker and create a WMV file.
    As a test, I tried converting a file that I had successfully converted to WMV before. Now neither program is able to convert this same file to WMV.
  4. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    What version Huffyuv is it? When I "upgraded" to 2.1.2 it gave me a weird output file that it wouldn't let me edit. Programs would crash like you're describing. I went back to 2.1.1 and everything went back to normal.
    Have you tried converting other codecs to WM9?
  5. Jeff Jacobson
    Dec 24, 2001
    2,116
    I'll try that too.
  6. Jeff Jacobson
    Dec 24, 2001
    2,116
    I went back to 2.1.1 and WME worked again. Thanks.
  7. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    wow I actually helped someone. [​IMG] The pleasure's all mine!
