Windows 2000 Pro Problem
Discussion in 'Archived Threads 2001-2004' started by Chuck Stephens, Mar 17, 2003.
  1. Chuck Stephens
    Chuck Stephens Stunt Coordinator
    Apr 25, 2002
    149
    I'm hoping someone can give me some advice on this little problem i have. When I first start up windows it takes several minutes once it's actually booted for internet explorer or outlook express to work. If I click on them during that period they lock up and don't do anything.
    I don't know if I should do a clean install of the OS or what since I've only had this on the machine for about 6 months. I've heard of having to reinstall win95-98 every 6 months or so but never win2000. Any help someone could give me would be greatly appreciated.
  2. Chad Ellinger
    Chad Ellinger Second Unit
    Jun 18, 2000
    269
    What version of IE/OE are you using? What type of internet connection do you have? Cable, DSL, Dial-up? If you have a broadband connection, are you using a cable/dsl router?
  3. Chuck Stephens
    Apr 25, 2002
    149
    Both IE and OE are version 6. I have a cable connection without a router.
  4. Chad Ellinger
    Jun 18, 2000
    269
    Did you try running Internet Connection Wizard again? In IE, go to Tools / Internet Options / Connections / Setup.
  5. Chuck Stephens
    Apr 25, 2002
    149
    I'll try that but i'm getting a sinking feeling that i may have to reinstall windows. Other programs are starting to have problems and my virus checker says there's nothing wrong.
