Patrick_S
- Apr 1, 2000
Ok I screwed up my W2K Pro install somehow and I'm looking for some advice.
I was tinkering in the Networking properties and I must have changed my laptop's Domain. This is a stand-alone notebook that isn't on a network and now when I try to Login to start W2K I get the following message:
The system could not log you on. Make sure your user name and domain are correct, then type your password again. (The usual information about the password being case sensitive.)
I know that I'm using the correct user name and password but there is no place to check if I'm using the correct domain. I find that odd because I remember once being able to type the domain but now there is no line to even see the domain.
I have the boot disks and the W2K Pro CD so I could always reformat and start from scratch but I would like to keep that as a last resort since I know the build is ok it was just my error that has created this problem.
Is there any way to boot to a command prompt and hack away the login file so that next time I boot it will complete the boot process without a login?
Thanks in advance for any help.
