Dennis Nicholls
I just got through updating my household's desktops and laptops to 24H2. I found that the Latitude 3500s and Optiplex 3060s would only be offered the 24H2 update on Windows Update if the "get the latest updates" switch was toggled ON.
The 24H2 supposedly has a large amount of code re-written in Rust language, which means replacing a lot of code. Once downloaded it takes a long time to install, and quite a bit of time after restarting. Expect at least an hour. Installing is very CPU intensive. An i3-8145U laptop showed 100% CPU use on Task Manager quite often, while staying under 50% on an i5-8500 desktop. The install on the laptop took a good deal longer to complete.
In general no major issues after the update. Biggest bug was deleting the printer driver for my Canon MF462dw AIO. I re-installed the driver and the printer came back, both printing and scanning. I keep the Settings icon on the Taskbar and it removed that too. I had to put Settings back there.
