Vince Maskeeper
- Jan 18, 1999
Ok.
As you might know- in a standard PC setup, the analog output from the back of the CD drive is routed the soundcard directly. So when playing back CD, the computer is just acting as a controller, and the audio is bypassing the processor completely and playing back direct to the card.
In my house I have 2 PCs that do not allow you to connect the analog output directly to the card. My HTPC has an M-Audio Audiophile card, and my desktop machine has an Echo Audio Gina studio card.
So, for these cards, I have to use a program that can actually read the data off the cd via the IDE controller, convert it, and send it to the audio card.
I recently installed WINAMP on the HTPC- and it worked perfectly right off the bat (for the HTPC the connection from the card to the receiver is digital- so maybe it is able to deal with passing spdif PCM striaght from the disc to the receiver).
However- I cannot get Winamp to work on CDs with the Echo card. I can get Windows Media Player to work fine (in decodes cds in the digital realm)- but I hate Media Player and would much rather use winamp.
Does anyone know the right settings/plugins to use to make Winamp play CD audio back in the digital domain- rather than just passing it via the analog on the drive? Again, My HTPC did it fine without any work, but I'm guessing it's because it's passing direct from the drive to the SPDIF output on the card. I know it's possible on the desktop machine because WinMedia Player works fine.
-Vince
-Vince
