Winamp 3 beta 3 - WOW!!!
Discussion in 'Archived Threads 2001-2004' started by Artur Meinild, Feb 27, 2002.
  1. Artur Meinild
    Artur Meinild Screenwriter
    Aug 10, 2000
    1,294
    Winamp 3 beta 3 is the coolest player I've ever seen, hands down, no contest! [​IMG]
    It supports true transparency under 2000 and XP, which means you can set opacity at 80%, set Winamp always on top, and still see through to the other applications underneath.
    This new version also has anti-aliased edge support, and some of the new skins are truly magnificent. I'm officially freaked out about this new release... Yummy!
  2. Pete_S
    Pete_S Stunt Coordinator
    Apr 10, 2000
    239
    Wow, thanks for pointing out the opacity. I really wouldn't have noticed otherwise. I was happy enough that this release played without crashing. [​IMG] This is icing on the cake.
  3. Kelley_B
    Kelley_B Cinematographer
    Feb 27, 2001
    2,324
    where did find WinAmp 3 skins at I looked but couldn't find them, maybe I'm just blind.
    Oh and the new version really cut down my CPU usage!!! Love WinAmp 3.
  4. Pete_S
    Apr 10, 2000
    239
    Kelley, on the Winamp 3 download page there's a group of text links under the one big download button for Winamp 3 itself... One of those is for the Winamp 3 skins. There aren't many there right now, but the list is certainly growing.
  5. Camp
    Camp Cinematographer
    Dec 3, 1999
    2,301
    Are there any functional differences....or is it all cosmetic?
  6. cafink
    cafink Producer
    Apr 19, 1999
    3,043
    37
    Carl Fink
    Is that all it does? Look pretty?
  7. Masood Ali
    Masood Ali Supporting Actor
    Jan 31, 2002
    921
    The interface options are much different, and vary from skin to skin. You can have it just like your 2.xx Winamp, or you can use a skin that looks a lot like Sonique, but without Sonique's clunky playlist.
  8. Kimmo Jaskari
    Kimmo Jaskari Screenwriter
    Feb 27, 2000
    1,528
    I like the crossfade functionality too, ie when listening to a set of songs the songs fade in when switching. Rather a cool effect.
  9. Artur Meinild
    Aug 10, 2000
    1,294
  10. Masood Ali
    Jan 31, 2002
    921
    I tried using the kaolla skin, among others. They look great, but their layout is godawful.
    I decided to stop playing hide-and-seek with Winamp and just loaded the default skin.
  11. AndyVX
    AndyVX Supporting Actor
    Aug 2, 2000
    804
    Well, I'm sold. Must download Winamp ver.3.
    Thanks for the heads up.
  12. AndyVX
    Aug 2, 2000
    804
    This question may seem dumb, but how do I set up transparency for programs and such under WinXP?
    Thanks.
  13. Kimmo Jaskari
    Feb 27, 2000
    1,528
    I really like the corner amp skin. Very unobtrusive but easy to get at when you have to.
    Also very clear as to what button does what, IMHO.
  14. Wes Bolton
    Wes Bolton Auditioning
    Oct 6, 1999
    13
    Andy,
    Sorry, but to get Transparency in XP, the program has to call the functionality (Like Trillian or Winamp3) OR you can buy software from Stardock that allows you to do this for ANY program in XP. It's called WindowFX. It's $49 subscription, but well worth all the really cool functionality it allows you to do with skinning, transparency, startbar replacement, and shadows. It enabled me to have a true HTPC with a custom look.
    -Wes
  15. Kimmo Jaskari
    Feb 27, 2000
    1,528
    I think it should be pointed out that the one-year subscription is for the Object Desktop package, which is a whole slew of programs including WindowBlinds and WindowFX etc.
    I'm also a subscriber, definitely lets you create a cool looking - and very functional - desktop.
  16. Mike_G
    Mike_G Screenwriter
    Jun 1, 2000
    1,477
    14
    Mike
    I had to get rid of WinAmp 3 for the time being:
    Doesn't sort by pathfilename (have you tried sorting 80+ tracks?)
    Doesn't use CDDB
    Without these, I can't use it. When the final version comes around, I'll definitely use it. Until then, it's WinAmp 2.78.
    Mike
  17. Kelley_B
    Feb 27, 2001
    2,324
    WinAmp 3 = a version of WinAmp that finally shuffles worth a damn!
    I have 1000+ MP3s on my hard drive here at work and with 2.xx I was constantly hearing the same 10 over and over again.
