Winamp 2.81 - How do you get it to "add" a song w/ a dbl-click??
Discussion in 'Archived Threads 2001-2004' started by kurt_fire, Mar 14, 2003.
  1. kurt_fire
    kurt_fire Stunt Coordinator
    Dec 29, 2002
    183
    For example, if I'm playing a song in Winamp 2.81, and I double-click on a different song in my music folder, Winamp stops and removes the song it's playing and starts playing the new song I double-clicked on. How can I get Winamp to just add that song to the playlist and not remove the one it's playing. I know I can right-click --->enque in Winamp, but can't I just double-click a song to add it instead of right click, move down, and enque. Thanks guys.
  2. Tony-B
    Tony-B Producer
    Jun 30, 2002
    3,768
    I figured it out. Here is what you do. Pull up the menu. Go to, Options, Preferences. In the preferences, go to File Types, which is located under setup. Over on the far right side, just below the two Winamp logos will be three checkboxes. Check the one that says "Enqueue as default action". That will make it so that when you double click a file, it will add it to the current playlist.
  3. kurt_fire
    Dec 29, 2002
    183
    thanks for the help my friend.
  4. Joe Hsu
    Joe Hsu Supporting Actor
    Jul 2, 2001
    812
    Normally your pull-down right-click menu should've offered "play in winamp" and "enqueue in winamp"...but if you have to have it via the double-click, then I guess that's the way to go. [​IMG]
  5. Tony-B
    Tony-B Producer
    Jun 30, 2002
    3,768
    No problem there, Kurt.
