Will Yamaha DVD-S2500 support HDCD?
Discussion in 'Playback Devices' started by ScottLR, Jan 26, 2005.
  1. ScottLR
    ScottLR Stunt Coordinator
    Nov 28, 2003
    68
    Thanks in advance.
  2. FeisalK
    FeisalK Screenwriter
    May 1, 2003
    1,245
    I doubt it, not seen any Yamaha equipment with HDCD support. You could always find the specs (probably on Audioholics)
  3. Howard_You
    Howard_You Stunt Coordinator
    Sep 16, 2003
    60
    Actually, although it's not stated in the specs, the Yamaha DVD-C750 changer recognizes HDCD disks.
  4. FeisalK
    May 1, 2003
    1,245
    oh.. all CD and DVD players will play HDCD discs as if they were normal CDs. What i meant - and assumed the question asked - was if there was HDCD decoding.
  5. EricRWem
    EricRWem Screenwriter
    Jun 4, 2004
    1,097
    Adrik
  6. ScottLR
    Nov 28, 2003
    68
    Thanks for the link, Eric. I had seen it and, while it doesn't say HDCD and the machine doesn't have an HDCD insignia, one never knows.
    And yes, Feisal, I'm looking for decoding capability. I have a lot of HDCD.
    I'll probably end up with the 3910.
  7. Howard_You
    Sep 16, 2003
    60
    Feisal,
    I wasn't clear enough...I meant to say that the C750 recognizes HDCD as different from CD and displays 'HDCD' instead of 'CD' on the on-screen display. I'm *assuming* this means it's doing some sort of different decoding.
  8. FeisalK
    May 1, 2003
    1,245
    Howard, that's cool.. didn't know that Yamaha supported HDCDs. Wonder why they don't advertise the fact. Maybe the 2500 does have HDCD but its an expensive experiment if they don't put it in their specs [​IMG]
    geez.. its not in the C750 manual even?
  9. Howard_You
    Sep 16, 2003
    60
    Feisal, yea I'm surprised they don't mention it either. I don't recall seeing it anywhere in the manual.
    I think part of the c750 is rebadged Phillips gear, do you happen to know if they advertise HDCD support?
  10. FeisalK
    May 1, 2003
    1,245
    Howard, not seen any Philips with HDCD support either. and neither companies are listed in HDCD.com
    did someone make a copy of the Pacific Micronics decoder chip on the sly?
