Will Upgrading Speakers effect/damage Receiver? (1 Viewer)
NickC
If I was to buy a new set of speakers to replace my current ones, will this effect(damage, effect sound, or anything) my receiver in any way? I just bought a new Yamaha htr 5490 and I am running some old speakers until I get the Money to purchase a new pair.. right now I have 6 ohm speakers and I plan on getting 8 ohm, I have my receiver switch set to handle 4 ohms and higher, but when I get the 8 ohm speakers I will switch it to the 8 ohm setting?
thanks
nick
ColinM
Yeah, go to 8 if your speaks are greater than / equal to 8 ohms. No damage will occour that way.
Likely, depending on the make / model of speakers, you will get an improvement. But there are tons of "old" speakers out there that will spank "new" models. I'm sure you understand.
- C
NickC
alright, thanks, I just bought the receiver and its not really that my speakers are old, maybe 5 years, but more or less not really good, they came with an old awia system, and I am just using the speakers temporarily until i can buy new mains and I didnt want to damage my new receiver because of the different powers and what not.
nick
Bob McElfresh
Hi Nick:
Think of it this way:
A short-circuit is zero ohms. This is bad.
The higher the impedence on a speaker, the safer it is (because it's farther away from zero).
Hope this helps.
samtbax
