MikeSHU
- Sep 30, 2004
I want to hook up my computer to the budget home theatre system I'm about to build. My receiver will probably be a Denon AVR 1800, my DVD Audio/Video Player is a Pioneer DV-578A, my CD changer is an ancient Sony CDP-C435, and my computer is where most of the music will come from and it will be hooked up via coaxial digital out. Finally, my speakers are powered Diva Swan M200 studio monitors.
The speakers will be connected to the receiver via the stereo pre-out's since they have their own amplifier.
Now the problem is my DVD-A player. I want to play DVD-A's at full 24-bit 192 KHz quality. This means I can only use analog inputs. Does my receiver have to specifically support DVD-Audio even though it will be imputed via analog stereo? I don't see any reason why it should not. The analog signal will go from the DVD-A player to the receiver with will route it to the pre-outs, right? I heard some where that DVD-A has some encryption mechanisms that make copying it, even via analog, impossible. Is this true? Does this apply to me since the analog DVD-A stream is being sent to the receiver that doesn't specifically support DVD-A?
Also, my ancient Sony CDP-C435 (if it sounded good in 1993 it should sound good now) has two outputs labeled "fixed" and "variable". What is the difference and which one do I use?
