Will this multi-switch amplify my signal?
Discussion in 'Archived Threads 2001-2004' started by Jerry Almeida, Aug 3, 2002.
  1. Jerry Almeida
    Jerry Almeida Second Unit
    Jun 7, 1999
    421
    Tampa, FL
    Jerry Almeida
    It's the RCA Distribution Multi-Switch (D6530)
    http://www.rca.com/product/viewdetai...CI345,00.html?
    Sorry if this is a dumb question but I need help.
    Currently my home set up is, (1)dual lnb satellite, (1)sony ultimate tv receiver, and (1)standard rca satellite receiver.
    A while ago I purchased a multi-switch from radioshack, so I can take advantage of the ultimate tv receiver. The switch worked however two channels on the rca receiver stopped coming in very well. When I took the multi-switch out of the set up, the channels were fine. I figured that I was losing signal strength with the multi-switch, so I should purchase one with an amplifier. So I bought the one mentioned at the beginning of this post, the D6530. When I set everything back up again those two channels still don't come in well. When I un-hooked the multi-switch they were fine again.
    Can any help me identify what the problem is?
    Jerry
  2. Jerry Almeida
    Jun 7, 1999
    421
    Tampa, FL
    Jerry Almeida
    Anyone? Anyone?
  3. Reece
    Reece Stunt Coordinator
    Apr 3, 2002
    94
    Try terminating the unused connections on the multi-switch with a F connector ( I think that's what it's called). Anyway, it's a small cap that screws on to prevent image ghosting and other picture distortions.
    Hope this helps.
  4. Jerry Almeida
    Jun 7, 1999
    421
    Tampa, FL
    Jerry Almeida
    Thanks! I'll look into trying that.
    Any idea how much an 'F connector' costs?
  5. RichN
    RichN Stunt Coordinator
    Jan 15, 2002
    72
    Radio Shack has them for less than $2.00 each.
    RichN
