Will the Pioneer 47Ai play 7.1 properly?
Discussion in 'AV Receivers' started by KyleT, Sep 27, 2003.
  1. KyleT
    KyleT Stunt Coordinator
    Nov 8, 2002
    59
    I'm planning on getting the Rotel RSP-1066 Preamp/Sound Processor. It decodes 7.1 surround sound. But my question is, will the Pioneer 47-Ai DVD player play 7.1 sound for movies/music/etc? I've seen it referenced as both a 6.1 player and a 7.1...
    Does a DVD player even need to meet any requirements to be able to utilize 7.1 soundtracks, or is it my Rotel that will be taking care of all of that for me?
    Kyle
  2. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    Kyle- You need to understand what the "common" useage of 7.1 means. [​IMG]
    Nothing. [​IMG]
    There are no 7.1 formats. What most people mean by 7.1, is the speaker system on which you are playing material. DD/DTS are 5.1. DD EX/DTS-ES are 6.1, although DD EX is a matrix derived 6.1 format, whereas DTS-ES can be 6.1 discrete or matrix derived.
    No 7.1. Although there are pre/pros that *create* a 7.1 soundfield out of 2.0 - 5.1, and 6.1 discs. The Rotel 1066 is one of them. So rest assured, the Pioneer will do everything you need it to.
