Frank Carter
- Mar 12, 2002
-I've been looking into SV subwoofers lately and I'm considering the 16-46pci or 16-46cs+/(not sure of amp). I think 1 SVS should satisfy my bass needs for now(I'll get a second of the same sub when I move at the end of the summer).
-So far the sub I've liked the best was the Legacy Deep Impact($1595). It by far gave more violent, grab me and shake me bass than any other sub I've heard(mostly store demoes). Unfortunately, I can't afford it right now. If you've heard this sub, I want to match(or beat) it's quality/levels of bass.
* Will 1 or 2 SVS put me there?
* Will there be much difference in levels of bass between the Pci and CS+/with Samson S1000.
-If I go with the cs+, it pushes me a little over budget when I add the Samson amp. The Samson S1000 is on sale at a local music store(www.marsmusic.com) for $399. I saw another Samson F1200 for $359, it's rated at 600x2rms@4ohms.
* Is this just untrue, how can the more expensive amp of the same manufacturer deliver less power for more money?
* Should I go with the Samson that SVS recommends?
-There is even a Crown XLS402 400x2@4ohms for only $299.
* Will this be inferior when compared w/ the Samsons mentioned above?
By no means do I want to skimp on quality amp but I'm not rich yet. I would rather find a way to get more money than settle for something less(within reason).
Sorry for such a long post but I'm having a really hard time convincing myself to buy something I haven't heard. I still haven't ruled out other subs but from what I'm reading SVS pack the most bang for the buck.
Rest of associated equip. is Klipsch RF-3II, RC-3II, RS-3II powered by Parasound HCA-855a/Yamaha HTR-5280 as preamp and connected to Toshiba SD-9200 DVD player.
*THANKS TO ANYONE WHO TAKES THE TIME TO ANSWER*
