Will receivers convert HDMI to component? (1 Viewer)
jeff peterson
With the upcoming high def DVD players supposedly in the pipeline; I understand they'll only output the high def signal via HDMI. MY HDTV is a Toshiba with only component inputs. Anybody know if the upconverting receivers that have HDMI input will pass a 1080 signal through the component outputs?
BradJudy
No - this would equate to stripping of the copy protection which would be illegal.
Westly T
Agreeded, No you can't. I have the Denon AVR-4306 and nothing is scaled through component either, it's just converted and remains in the same resolution. You have to use HDMI to take advantage of the advanced features.
I have a 65 Mits that doesn't have HDMI or DVI, I'm hoping someone will come up with a HD modulator that can take an HDMI signal and output a digital HD signal the built in HD tuner can accept or an upgrade module for the set. My set also has firewire, but I've never owned anything else using it.
apearson28
