Will Progressive Scan DVD make much difference on 27" HD ready set?
Discussion in 'Archived Threads 2001-2004' started by BrianGC, Aug 27, 2002.
  1. BrianGC
    BrianGC Stunt Coordinator
    Aug 19, 2002
    104
    Hi,
    I'm considering the purchase of a Zenith C27V22 27" HD ready set. It has 2 Component inputs, but only one of them is 1080i. The other is for a standard DVD player.
    As of now I don't have a HDTV source, so I could hook up a progressive scan DVD player. But in the future with an HD cable box or Sat. receiver, I'd have to use the standard component input for the DVD player. I'm wondering if you could even tell the difference between the progressive scan and standard DVD on a 27" set?
    BrianGC
  2. MikeyWeitz
    MikeyWeitz Supporting Actor
    Feb 10, 2002
    939
    Difference wont be huge, but you will notice it for sure. MIght as well get one now since they are fairly cheap and worry about using a component switcher for when you get 1080i.
