Will NTSC discs play on a Pal system?
Discussion in 'DVD' started by Mick Wright, May 9, 2004.
  1. Mick Wright
    Mick Wright Second Unit
    Mar 10, 2000
    346
    I'd like to send some home movies recorded on NTSC dvds to a friend of mine in Spain. Can anyone confirm if these discs are likely to play on a pal system? Thanks.
  2. jason:g
    jason:g Stunt Coordinator
    Apr 16, 2004
    242
    Using NTSC->PAL conversion, it can be done.
  3. Mick Wright
    Mar 10, 2000
    346
    This guy most likely has a regular, unmodified pal player with minimal features. Does that mean the answer is no?
  4. Eric.
    Eric. Stunt Coordinator
    May 6, 2004
    63
    As far as i know all dvd players in pal regions are also ntsc capable.I have never come across a machine that won't play ntsc discs here in australia even down to the cheapest and nastiest.You will of course need a monitor capable of displaying an ntsc signal as well.Most half decent tv's sold in the last 5 years are ntsc compatible.
  5. Sean Aaron
    Sean Aaron Second Unit
    May 17, 1999
    254
    Sean Aaron
    If the tv is multistandard and he's using SCART to connect the DVD to the tv there shouldn't be an issue.
  6. Peter Svensson
    Peter Svensson Second Unit
    Nov 25, 2003
    404
    Yes, it´s not the DVD that´s the problem. As far as I know all DVD´s can play both NTSC and PAL, it´s the TV that´s the problem. That´s why there are NTSC to PAL converters or the opposite. If he has a multisystem TV it should be no problem. But maybe it´s only possible to use the a certain connection, scart, S-video or video.
  7. Sten F
    Sten F Second Unit
    Apr 19, 2003
    284
    Your friend in Spain shouldn´t experience any problems playing them. All he need is a newer televison set and a cheap multi-player or modified player. That´s it.
  8. Mick Wright
    Mar 10, 2000
    346
    Thanks for the advice guys.
  9. John*C
    John*C Stunt Coordinator
    Aug 8, 2003
    203
    Like us using NTSC there are work arounds for all systems for all of the countries, I would use a inverter custom to PAL. Converters are used to lower the electricty needed to play on NTSC players, whereas PAL has a higher current level than what's found the USA grid.
