Kevin C Brown
- Aug 3, 2000
here's how I would think about it:
There are the speakers themselves, the surrounds and rear(s), and then there is the image too.
So for the 1st row, if the surrounds are directly to the sides, the image will be heavily pulled towards them, but it will still end up behind because of the rear(s).
But the back row is trickier because the surrounds will be forward, and even the image will probably will be pulled slightly foward too. (But then again, as far as Lexicon goes, having the surrounds' image slightly forward of the seating position is not necessarily a bad thing.)
I guess here's another question: considering the front row and back row, how often do you expect the back row to be populated? In other words, at what row would you want the best sound? (Hee, hee: where will *you* be sitting?)
Man, ... Not easy to think about! Now I understand where you're coming from...
And unfortunately some more q's: at what seat will you balance levels? Middle about 14 ft back? Any way you could (for now) set the stuff up and try out the different scenarios before construction?
