Will my 8 ohm amp handle 6 ohm surrounds?
Discussion in 'AV Receivers' started by Ken.L, Jan 24, 2004.
  1. Ken.L
    Ken.L Stunt Coordinator
    Jan 7, 2004
    58
    I've got an entry level Kenwood HTB-206 package system and the receiver is rate for 8 ohms and higher. I'm upgrading the speakers and have a pair of 6 ohm Wharfedale WH-2 surrounds ordered. The mains are going to be 8 ohm BIC Venturi 52's. Will the receiver handle the WH-2's without problem or is there going to be a melt down? What exactly is going to happen? Thanks in advance.
    Ken
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    You should be fine.
    In truth, your 8 ohm speaker are only 8 ohm's NOMINAL. The impedence actually depends on what frequency of sound they are trying to produce at the moment.
    And while 6 ohm speakers will draw more current, these are the surrounds, not the mains so they wont be used as much.
    I would try to avoid cranking the volume way up and making sure you over-compensate for heat/venting around the reciever. Keep an eye on the temperature and you should be fine.
  3. Mike_Skeway
    Mike_Skeway Second Unit
    Jan 13, 2004
    265
    No problem. Nothing will happen, you will be fine.
  4. Ken.L
    Jan 7, 2004
    58
    Bob, Mike,
    Thanks for the reassurance. It does seem like I only hear sound out of the surround only a small percentage of the time watching a DVD and of course they are not even on in stereo mode for listening to music. So, the amp will only be looking a 6 ohms a small percentage of the time.
    Ken
