Ryan Cruz
- Apr 2, 2002
If I upgrade my receiver from 70 WPC to 125 WPC, will I also hear an improvement with the bass of my subwoofer?
If I upgrade my receiver from 70 WPC to 125 WPC, will I also hear an improvement with the bass of my subwoofer?What kind of improvement are you looking for? Quality or impact? What kind of sub do you have? If your sub has its own internal amp and you're sending a line-level signal to the sub via the LFE out, changing to a higher powered receiver is not going to change your sound. Try moving the sub closer to or further away from the corner of the room. The closer to the corner, the more bass you get. If your problem is too much bass, move the sub away from the corner. If you have a passive sub (no built-in amp), then getting a separate amp for the sub might be the ticket.
