Will I notice a difference if I upgrade
Discussion in 'AV Receivers' started by russ_hudson, Jan 17, 2004.
  1. russ_hudson
    russ_hudson Auditioning
    Mar 14, 2003
    5
    My current receiver is a JVC RX7000V and my speakers are all Sony speakers that are about 4 years old (front speakers are SS-U481AV). My subwoofer is an Infinity Interlude IL100.
    I am looking at upgrading my receiver to an Onkyo SR601 but am curious if I would really notice much of a difference. I use my system basically for HT use only.
  2. Justin_D
    Justin_D Stunt Coordinator
    Dec 27, 2003
    217
    I upgraded from a 1 1/2 year old Sony receiver from a HTiB, and at the time I only had 2 Polk R20 bookshelves, and the rest were the stock satelites. Stock sub too. HUGE difference. Especially 2 channel signals, mostly TV. I upgraded to an Onkyo TX-SR501, just a step down. I say go for it!
  3. V JACKSON
    V JACKSON Agent
    Dec 2, 1998
    27
    Russ, although you might notice a difference in performance of your system with a new receiver, based on your system I would recommend upgrading your speakers first, as they really determine how your system sounds and also the fact that while Sony is a great electronics company, they are not a speaker manufacturer ie; Klipsch, Polk Audio, Energy, B&W, ETC...............
  4. Ernest Yee
    Ernest Yee Supporting Actor
    Jun 6, 2003
    539
    Yeah - I agree w/ V Jackson - your speakers are definitely way worse than your receiver. Maybe grab onto a Polk RTi closeout deal? That would probably be most economical depending on your budget, otherwise I would say go used w/ a better company.
  5. MichaelBAr
    MichaelBAr Stunt Coordinator
    Jan 16, 2004
    72
    Are kenwoods good? I have a pair of klipsch and an extra pair of kenwoods in the garage?
  6. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    The Kenwoods with all due respect, belong in the garage. My own opinion is that there's little to commend Japanese speakers while those that come from say China seem to be made with better components and a better understanding of design principles.
  7. russ_hudson
    Mar 14, 2003
    5
    Thanks for the response guys. I believe I will replace my speakers before I replace my receiver. Let me ask one last dumb speaker question. I am not in a position where I can go and listen to a lot of speakers and I will be ordering my speakers online. In my case, what should I look for as far as deciding on speakers?? What specs and so forth??
  8. Ernest Yee
    Jun 6, 2003
    539
    What's your budget?
  9. russ_hudson
    Mar 14, 2003
    5
    My budget is around $1000 for speakers and a new receiver (I am planning on keeping my Infinitey subwoofer). The receiver I have been looking at is the Onkyo SR601 which I can get for around $350 - $400.
  10. Marty M
    Marty M Cinematographer
    Dec 6, 1998
    2,917
    11
    I know you can save money ordering on-line, but you really can't replace a live audition of speakers to decide. Specs are not as important as how the speakers sound to you.
    If you are set on ordering on-line, make sure that the company offers a 100% money back guarantee if not satisfied. Just my 2 cents worth, FWIW.
  11. Ernest Yee
    Jun 6, 2003
    539
    Personally, if it were me w/ that money, I would probably spend $1000 on a great pair of bookshelves (maybe the matching center if you can stretch it but you might just want to phantom in the meantime) and a receiver to hold you off while you slowly expand the set.
    Even an Axiom set will run past $1k which would leave no room for the receiver end. But if you piece it out, you can make an OUTSTANDING set vs a mediocre set if you do it all at once.
    That Onkyo IMO wouldn't be too great a jump. You might want to look into that Denon deal - that receiver would probably last you a while although that would require more budgeting since it's at the $700 range. But it would power a lot more speaker than the Onkyo.
  12. Shane Martin
    Shane Martin Producer
    Sep 26, 1999
    6,017
    IMHO this is a mistake. The biggest issue I find with speakers with a return policy is that if you have to box them back up because you don't like the sound you are going to be influenced more to keep them due to the time and trouble it takes to do this. In this case you are going to stick to what you bought and be disatisfied in the long run.
    I would use a site like Audioenvy to your advantage before I'd take what literally is a shot in the dark when buying Online speakers.
    How old are the Klipschs in the garage?
  13. V JACKSON
    V JACKSON Agent
    Dec 2, 1998
    27
    I wouldn't recommend you buy speakers on-line without hearing them first. Again these are what ultimately determine how your system sounds. Take the time and go LISTEN to various brands, and then look for the best deal on-line if you want.................
  14. chun howe
    chun howe Stunt Coordinator
    Apr 18, 2003
    119
    $1000 for speakers (i believe its front, rear and center) budget, your option will be limited.
    checked out hookontronics.com for energy speakers.
    etronics.com is another place you can get great deals.
    believe me, i had the same budget to start with but the more you hang out here the budget will increase rapidly[​IMG]
    by the time i am done shopping i double my budget.
    not counting upgrades.[​IMG]
  15. Minesh Patel
    Minesh Patel Stunt Coordinator
    Sep 7, 2003
    50
    Well, you could get the Rocket ELT minus sub for $699 - many, many raving fans here and at AVSforum. Check them out: www.av123.com
    For the record, I own Axioms [​IMG]
