Will Dig Sat Rcvr make difference?
Discussion in 'Archived Threads 2001-2004' started by Lisa, Aug 14, 2001.
  1. Lisa
    Lisa Extra
    Apr 2, 2001
    20
    I presently do not own a Digital A/V receiver. I can't afford the ones I really want for at least a year or so. Would it be worth it to get a Digital Satellite receiver in the meantime? Will I notice a difference in the sound quality?
    Lisa
  2. Mike__D
    Mike__D Supporting Actor
    Dec 27, 2000
    617
    If it's anything like digital cable TV, then yes, you'll get an improvement with sound and video. I upgraded to digital cable tv a few months ago, and the sound and picture were better on the digital channels. But, my local channels weren't digital, so I didn't notice an improvement there. Not sure how the satellite deals with your local channels.
    On thing I've noticed though, the digital channels can't hold a candle to DVD's video. Apparently they send through the lowest bitstream they can get away with in order to squeeze in the numerous music only channels I also get... but this is mostly likely just my cable provider (Comcast). Again, not sure what the deal is with satellite.
    Mike D.
  3. Vin
    Vin Supporting Actor
    Oct 23, 2000
    546
    Lisa, basic (digital) satellite receivers only output left and right analog audio which can be connected and played back through your TV's speakers.
    A more expensive satellite receiver that can also output a digital audio signal needs to be connected to a Dolby Digital receiver which will decode that signal for playback. If you don't have a receiver and you're planning on connecting directly to your TV, you'd have to do so with the analog cables only.
    Hope this helps.
  4. Lisa
    Lisa Extra
    Apr 2, 2001
    20
    Thanks Mark
    Thanks Vin
    I do have an a/v receiver at the present time with surround sound speakers. It's a rather old Onkyo set up that I received in 1995 (not dolby digital). So will the dolby digital satellite receiver (SAT-A55) make a difference in the playback through my surround system??
  5. Vin
    Oct 23, 2000
    546
  6. Gordon B
    Gordon B Agent
    Jan 8, 2001
    32
    Lisa -- FWIW, I have had a Hughes Dolby Digital receiver(model HIRD-D45)for two years and have gotten very little use out of it. Just about the only programming in DD is on HBO, Showtime, etc. If you have a DVD player and a DD receiver, I can almost guarantee you won't want to watch movies on premium channels when you can watch them on DVD, which has way better sound. Direct TV used to have a Dolby demo channel(I believe it was channel 900) that had a smoking DD demo, but they stopped that about a year ago. I would save the $200 bucks or so and sink it in to your other equipment.
