Will .avi format play in my DVD player?
Discussion in 'Archived Threads 2001-2004' started by Jon Mercer, Mar 1, 2002.
  1. Jon Mercer
    Jon Mercer Second Unit
    Jan 24, 2001
    268
    At work I've downloaded some video clips off the net and want to burn it and play it in my DVD player but it's in avi format.
    Will it work or do I have to convert the format to something else?
    Thanks in advance
    Jon
  2. John Chow
    John Chow Second Unit
    Sep 18, 1998
    312
    Quick answer: No, it will not work. Most .avi's nowadays are compressed using one of the various divx encoders, none of which are compatible with dvd players. You can burn Mpeg1 files to a cd in VCD format and some dvd players may play them. You need to check if your dvd player has support for VCDs though.
  3. Jay Sylvester
    Jay Sylvester Supporting Actor
    Jan 27, 2002
    521
    I use Nero for burning, and it accepts AVI files for creating VCDs (video CDs). It converts them on the fly to the necessary format. As John said, check to make sure your DVD player can play VCDs.
