Will a KDS monitor with component video input play progressive scan input on screen?
Discussion in 'Archived Threads 2001-2004' started by Greg_TSL, Feb 19, 2003.
  1. Greg_TSL
    Greg_TSL Stunt Coordinator
    Oct 9, 2002
    71
    Friend asked me this, I wasnt sure.
    TIA
  2. Max Leung
    Max Leung Producer
    Sep 6, 2000
    4,611
  3. Greg_TSL
    Oct 9, 2002
    71
    Well I guess I can stop coming to this forum!
    Thanks!
  4. Max Leung
    Max Leung Producer
    Sep 6, 2000
    4,611
    Did you find the model number of that KDS monitor? None of them have a "component video" input except the KDS Radius Rad-5c (and other Radius flat panels, it seems) according to www.kdsusa.com.. It's pretty vague if they really use the 3 plug component inputs or not, but they mention "75 Ohms" which sounds right.
    I mentioned google because it looked like you hadn't tried that avenue of research yet.
    (I found the information using google...took me under a minute to find it. [​IMG] )
  5. Greg_TSL
    Oct 9, 2002
    71
    Ah, Thanks for the info, I am pretty sure its a 19" CRT, so thats probably why I couldnt find anything relating to component video info on it, he must be mistaken about the connection.
    Thanks again
    [​IMG]
  6. Max Leung
    Max Leung Producer
    Sep 6, 2000
    4,611
    Hey no problem. I can see why it was so difficult to find info on the monitors though. I must have lucked out finding the US site for KDS when using Google!
    Anyhow, it's likely his monitor may have 2 VGA inputs. A 15 pin DSUB (small connector) and a set of 5 BNC inputs. Weird looking round jacks that are larger than an RCA jack. If his monitor has only those two, then he can't use component video, which only uses 3 RCA-style plugs.
    Also, I didn't check for older KDS monitor models. That may explain why I didn't see much when I visited their site.
