Clay Autery
- Oct 23, 2000
...she says that to ME, even though SHE has stacks and stacks of CDs laying all over the place!
Between my wife's addiction to CDs and my ever growing DVD collection (not to mention our dinosaur collection of VHS), we are in serious need of additional storage space for media. I have been working and re-working a design for a 6-drawer media cabinet for some time now, and have finally begun construction...
First, a little about the specs:
- 6 drawers with 16" full extension ball-bearing drawer slides.
Drawers are dimensioned and divided in such that they will accomodate DVDs, CDs and VHS tapes with very little wasted space. Each drawer has five compartments and will hold:
135 DVDs or 285 CDs (don't have the VHS number handy) for a total of either 810 DVDs, 1,710 CDs, or any combination in between pretty much.
The basic design is a VERY minimalist, shallow-depth, cubist design with the dimensions: 44 3/16" H x 44.875" W x 17.5" D
It will easily fit against one of the side walls in the theater and has a relatively small footprint considering its capacity.
Each drawer will have a single, centered, flush-mounted pull (the type with the spring-loaded, flip-out handle), and the entire cabinet will ride on 4 transfers (one at each corner) similar to the ones I used on the Flexi-Rack.
Oh... and it is stackable to get a possible two cabinets high in any room with at least 7'-6" high ceilings (with the same footprint). Stacked cabs should probably be lag bolted through the back wall of the cabinet to the studs in the walls (which you will be able to grab two studs no matter how it is situated against the wall), though it will be quite stable even without the lag bolts.
So far I have accomplished the following:
-Acquired materials
-Completed cut list for all six drawers (total of 54 pieces!!)
-Trial fitted pieces to verify cut accuracy
-Determined top, bottom, front, back orientation of each piece and marked accordingly.
-Comlpleted layout (referencing the bottom edge on all pieces) for the biscuit slots to join the pieces.
-Cut biscuit slots in all backs, sides, and interior dividers.
-Designed and constructed the drawer pull plunge routing template.
I still need to layout machine the secondary stuff in the drawer fronts: biscuit slots for each side and 4 dividers, cut the 1/4" length-wise dado for the bottom panel, and plunge router the drawer front faces to accept the drawer pulls.
Then, I will of course glue up all the drawers. Once they are dry, I will verify the carcass dimensions based on the actual dimensions on the drawers to minimize drawer to carcass clearances. Then machine and join the carcass, fit the drawers/slides, install the drawers, adjust... adjust some more, etc.
Finally, I will need to figure out how to finish this piece... It'll be black of course, but I haven't decided whether to go for 1) laminate (to match the Flexi), 2) paint over MDF, or 3) dyed wood veneer... I do know that I am going to test out filling the MDF with bondo and sanding to get a smoother edge finish (idea picked up from a fellow flexi builder).
We're leaving town for the weekend, so Iwon't be able to get back to it until Monday...
Later y'all!
-Acquired materials
Later y'all!
