widescreen vhs wont work?
Discussion in 'Archived Threads 2001-2004' started by Pete Fleck, Dec 3, 2002.
  1. Pete Fleck
    Pete Fleck Auditioning
    Dec 3, 2002
    2
    I received a wide screen vhs tape (new). Went to play it in my vcr (connected to my normal aspect tv), and I have no picture. Just a blank screen. Does this sound normal? I would think I would get some sort of picture. Also, the digital counter does not work. Does this have something to do with the widescreen format of the vhs tape?(the counter works on all my other vhs tapes). I am thinking that the tape is bad. Just do not have another widescreen vhs tape to compare it to. What do you think? THanks for all help.
    pete
  2. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    afaik, there is no special encoding for a widescreen vhs tape. it's no different then a p&s tape.
    i'd say you have a faulty tape.
  3. BrentPollard
    BrentPollard Second Unit
    Dec 18, 2001
    445
    I agree, there is no difference as far your vcr reading the tape.[​IMG]
  4. Alf S
    Alf S Banned
    BANNED
    Apr 23, 2000
    3,477
    625
    4,110
    Alfer
    Sounds silly, but have you checked your cables to make sure everything is plugged in ok?
    If other tapes work in it ok, then tape is bad.
  5. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    There is no electronic difference between the picture material on a "widescreen" tape versus an ordinary tape, and no video processor, PC, VCR, or TV can determine the aspect ratio by analyzing the video in terms of pixels.
    A "widescreen" tape may or may not have a code that shows up on one of the scan lines 484-525 of the video output that tells a TV with automatic aspect ratio selection to go into 16:9 mode.
    Do you get audio? Does the show start and the picture appear after you fast forward a little ways into the tape?
    Video hints:
  6. Pete Fleck
    Dec 3, 2002
    2
    Thanks all for your replies. I bet it is a faulty tape like most said.
    pete
  7. Kevin P
    Kevin P Screenwriter
    Jan 18, 1999
    1,439
    If the counter isn't advancing, you have a bad tape. Did you try fast forwarding it a bit?
