Brian-W
- Feb 8, 1999
For all you widescreen lovers (and Pan and Scan haters), Phillips Electronics had a small kiosk off to the side (but facing the aisle between other booths for passerbys to see) showing the benefits of widescreen vs. pan-and-scan.
There was a double stack of two televisions, the upper television showing a pan-and-scan copy of Lawerence of Arabia, the bottom television showing the widescreen version of the same movie. Both appeared to be synced up so that attendees could clearly see the difference. If I recall correctly, the slogan above the televisions was "See the vision the way the director filmed it"
Anyway, good way to educate many of the attendees who are probably ignorant to the differences.
