Wideband Component Vs. "Regular" Component
Discussion in 'Archived Threads 2001-2004' started by Stephen Houdek, Mar 10, 2002.
  1. Stephen Houdek
    Stephen Houdek Second Unit
    Jan 21, 2002
    326
    S
    Ok guys, I know there is someone who can assist me. I "almost" purchased an Onkyo 787 on clearance. However, I'm now holding out until I get something cleared up.
    What is the difference between wideband and regular component inputs and outputs? Will regular component inputs and outputs not support HDTV and progressive scan DVD? I noticed this difference between the Onkyo 787 and 797 and thought I'd better not buy until I got this cleared up. Shouldn't there be one specification for component I/O?
    If anyone has the exact details on the signalling I'd appreciate it.
    Thanks.
  2. Jeremy Little
    Jeremy Little Supporting Actor
    Jun 9, 2001
    770
    That is correct. If you plan on needing to switch your Progressive component signals, get the 797.
  3. RAF
    RAF Lead Actor
    7,061
    Stephen,
    I don't know the component input/output bandwidth specifications of the 787 and 797 but I do know that there has been a lot of misconception regarding what is, and what is not needed to successfully pass progressive scan and HDTV signals through component switching on pre/pros and receivers.
    I referenced an article on this here and you should look it over to see if and how it applies to your situation.
    Take care.
  4. Stephen Houdek
    Jan 21, 2002
    326
    S
    Thanks.......I'll take a look.
  5. Stephen Houdek
    Jan 21, 2002
    326
    S
    Great link, it appears I need to be very specific and ask what bandwidth the outputs actually have. As long as it is above 30Mhz I'm alright. Interesting that it is analog as well.
  6. StephenL
    StephenL Second Unit
    Nov 21, 2000
    341
  7. RAF
    RAF Lead Actor
    7,061
    If the bandwidth is 50MHz for both the 787 and the 797 I wouldn't think that either would be a problem. Has anyone out there actually done a visual comparison with both models?
    I found, like the article stated, that the bandwidth "problem" has been greatly overstated in my practical experience. Granted, I haven't tested every component out there with component switching, but I've yet to find something that didn't do the job.
    My two cents on this.
  8. Tulli
    Tulli Stunt Coordinator
    Nov 20, 2001
    53
