Why tweak DVD player picture settings?
Discussion in 'Archived Threads 2001-2004' started by James Zos, Jan 20, 2003.
  1. James Zos
    James Zos Supporting Actor
    Jan 7, 2002
    725
    What I mean is, once you've calibrated your display device with AVIA, is there any reason to tweak your DVD player's picture settings? Assuming you mostly watch DVDS anyway (like I do), once I've set, say color and black level on my TV set with AVIA, why would I further adjust the DVD player's color and black level settings? Shouldn't you adjust one or the other and leave the other alone?
  2. James Zos
    Jan 7, 2002
    725
    Uh...Did I not phrase my question well? Does anyone not understand it? I can't believe no one has an opinion on this.
  3. John Royster
    John Royster Screenwriter
    Oct 14, 2001
    1,088
    James,
    I think it has more to do with flexibility. If you only have one or two inputs on the projector or scaler then it would be nice to have adjustments on the DVD player as well.
  4. James Zos
    Jan 7, 2002
    725
    John, if I understand you, you're saying that some people might calibrate their player for DVDs, while calibrating their projector for another input source as well? I had thought it might be something like that.
    Thanks for responding!
  5. John Royster
    Oct 14, 2001
    1,088
    James,
    That is my uneducated guess.[​IMG]
  6. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    I don't really know... I'm waiting for one of those video experts to respond. I would think (just a thought) that you would just want to calibrate the TV, although I guess I hadn't really realized or noticed that you can tweak things on the player end, which confuses me, because then, if the DVD player is out of whack, everything else that you play on the TV will be funny, if you used the DVD player to play Avia, or VE. Wouldn't you ideally want to calibrate the TV off of a perfect source and then calibrate the player to match that or something? Then again, I don't really worry that much if cable TV or VHS is a little off, the DVD is the more demanding.
  7. Jack Briggs
    Jun 3, 1999
    16,738
    129
    It is more demanding.
    For the most part, most DVD players probably are best left at their "neutral" or "flat" settings. However, I've used the DVD player's controls to fine tune certain discs (including MGM's transfer of 2001, which needs massaging on all DVD players I use).
  8. Phil Nichols
    Phil Nichols Second Unit
    Sep 7, 2000
    345
    Jack,
    I just purchased the anamorphic restored 2001 today. What tweaks do you typically have to do to it?
  9. James Zos
    Jan 7, 2002
    725
    Thanks for the additional responses!
  10. David Von Pein
    David Von Pein Producer
    Feb 4, 2002
    5,748
    10
    Heck, I wasn't even aware that you COULD tweak the DVD Player.
    How is this done?
    And are we talking "picture settings" (like on a TV): Contrast, Tint, etc.?
  11. John-Miles
    John-Miles Screenwriter
    Nov 29, 2001
    1,216
    3
    110
    Well I know for me once i finally get HDTV i will have 3 component sources and only 2 inputs, this means i will ahve to use the same settings for my DVD player and my PS2 (tv settings that is) So what i will do when this day comes is calibrate my tv using the PS2 then run avia on my separate player and tweak the player settings to get the same great results. That way i will get the ebst results from both. If however the players adjustments are limited, i will likely just use avia on that and deal with whatever my PS2 puts out.
  12. Donnie Eldridge
    Donnie Eldridge Supporting Actor
    Jan 3, 2001
    761
    There is also another reason. Many of us have multiple dvd players routed thru our pre/pro's and A/V receivers for switching. Due to variance's in dvd playback between different models and the fact we have limited inputs/memory settings on our tv's it is sometimes necessary to tweak playback.
  13. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    38,763
    488
    9,110
    My JVC XV-S65GD DVD player has video adjustment settings (just like those found in TVs) in the player's menu settings.
  14. Doug_B
    Doug_B Screenwriter
    Feb 11, 2001
    1,081
    As I now have a projector, I will now be looking at what I can tweak on my RP-91 to allow for disk-specific augmentations. For example, I'm not overly thrilled with the Star Trek: TNG transfers on the big screen (and the later seasons were soft even on my 36" TV).
    Doug
