todd stone
- Dec 1, 2000
for 3-6 ft of monster component at best buy or circuit city it's $60-90 ridiculous...
Just for fun, if you have a an extra A/V cable around the house, you know the red, white & yellow tipped ones, give'em a try and see what you think. Won't cost you nothing
This is not a very good suggestion though. The combo cables (Red, White, & Yellow) are made for composite video and 2 audio signals, not three component video signals.
The audio portion of those cables is usually different and of lower quality than the video portion. While that cable will pass the signal, it will do so less than optimally and you are much better off going with 3 well constructed 75ohm video cables or one well-contructed Component Cable.
Not unless you're using three identical "throw-away" cables. Give it a try.
Why? Not a good suggestion to simply "TRY" something? Come on
Mea Culpa.
Ok, to try it sure. I suppose that I took it to mean that you were suggesting that it were a viable alternative, which of course it is not.
So yes, try away...I would never want to dissuade anyone from experimenting.
